Serpentine belt removal
The following 2 users liked this post by avern1:
DavidYau (04-30-2020),
MattArnold (05-01-2020)
One suggestion
The belt on my 2000 xk8 was pretty tight. One tip for removal and replacing would be to get a serpentine belt tool. The tool is nice and long and makes it easy to get the leverage required. Many auto parts stores will loan you the tool. To make putting the belt on easier the tensioner on my car has no lip to go over so I just put a little silicon on it and with the tool was easy to just slip it on. My reason for changing the belt was a alternator replacement.
Johnken (05-02-2020)
2006 XK8....
I replaced what I assumed to be the factory serpentine belt in July 2018 when I had to remove the radiator fan assembly in order to remove the alternator so I could take it in for refurbishing. Much easier to replace the serpentine belt when the radiator fan assembly is out of the way and the hood is raised to the service position....
MattArnold (05-02-2020)
hawaiianjag
12-07-2015 07:54 AM
