Service manuals
They are all based on JTIS which was the dealer technical documention prior to 2003 when they went on-line.
Check out this link:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
My 2005 XKR is the first car I have owned where there was not some readily available and affordable hard copy service manual from either the manufacturer or an aftermarket publisher (like Haynes or Helms). I did download the JTIS CD that is somewhere between moderately helpful and useless.
Why is it that no one publishes something more usable in hard copy form for these cars?
Doug
Doug
After reading tons of messages here and on other sites, I'm not too sure the dealers have anymore information than we have. It appears most can't find any reason for the asc/traction messages. I've been receiving them. I was told by an independent Jag shop to shut down, wait at least 1 minute so the computer can reset. When you restart the message will be gone. Well this works for me, about once every other week.
JTIS and Alldate show nothing about this problem or how to fix it. Several people that have posted here say the same thing about the dealer's ability to find or solve the problem but they still collect your money (for doing nothing).
Have you looked into the possibility of the ABS module circuit board problem? On both of my cars xj6 & xk8 the abs / traction control light would go on when it wanted to. We could not find anything in the system that was failing. We found a TSB on my xj6 but it continued after we checked the connector. I ended up replacing both ABS Modules. I did not have this information at that time. You may need to sign into this page but it will give you a little insight on your problem. I did see a place that will rebuild your existing unit for you but I do not have it to give to you.
I am assuming that you checked all the wiring, connectors and sensors?
http://forums.jag-lovers.org/av.php?1216605k87
Question: What is the difference between ITT Super DOT 4 fluid and another company Super DOT 4 fluid (if you happen to know).
Gerard Radimaker
09-13-2015 10:33 AM
jagent
09-07-2015 05:00 PM
