She got no power
She got no power
Went for a ride. Stopped at my daughters said hi picked up my wife went to dinner. Got in started it up drove home the long way. Was getting dusk so the lights came on. The indicator on the dash that says your lights are on and some other dash light where flashing lightly. Almost not noticeable. Got home shut her down and everything was dead. Clicking noise and a red light on the shifter surround was flashing. She won't even turn over.
Brand new last year cause I was having similar problems. Charging system check out fine. Checked every ground connection I could find and the positive box in the trunk. Been going through these similar problems for over a year now. One time a month ago I went to Dunkin a Donuts to get a coffee,I figured I'd leave it running while I went in. When I opened the driver door it shut off. Every time this crap happened I do a hard reset and she starts right up.
The flashing light on the shifter shroud I will assume is the security light. Do you have a remote or a second key to see it will unlock the car? From what you are saying I believing that your car does not identify the key and it could be one of two things the key chip or the exciter ring at the key lock either one failing would prevent the car from starting. What is puzzling is that it shut down when you opened the door not sure what to think about that. First try another key or the remote for the car.
Rick7311
04-23-2016 08:51 AM
