Shift knob removal
Old 02-20-2010, 04:06 PM
dfwx's Avatar
Default Shift knob removal
I did searches to try to find an answer first...
How do you remove the shift knob on an XKR/8 (05)? I'd like to put a walnut one on. Is it a matter of just screwing it off? (If so, which way is the thread?) A set screw under there somewhere?
Anyone make a decent wood steering wheel that works with the cruise/stereo controls?
Thanks.
Old 02-20-2010, 04:32 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
Can't speak for the '05 but earlier cars has a 'lock nut' under the knob. I put black tape on an adjustable wrench, to prevent marring the finish and just unscrew the knob counter clockwise.
I put one of the figured walnut knobs with a green 'growler' embedded in the top on. Available on eBay all the time. Looks better than anything Jaguar ever installed.
Old 02-20-2010, 09:07 PM
dfwx's Avatar
It is the round chrome ring on the bottom? There is nothing that appears to be a nut.
Old 02-21-2010, 01:13 AM
XKR Brian's Avatar
It is pretty simple. I will go back to my first day as a mechanic. Lets see, what was the rule? Hot water on the left, payday on Friday. No wait, thats the rule for plumbers. Oh yeah now I remember, lefty loosy righty tighty. yeah that's it. counter clock wise that should do it. comes right off. Sorry had a bad day.
Old 04-08-2022, 08:58 PM
taylods's Avatar
Default Shift Knob removed (unscrewed) in 60 seconds
As "Test Point" said...
It's a 'lock nut' under the knob. I put black tape on an adjustable wrench, to prevent marring the finish and just unscrew the knob counter clockwise."
Here are some pictures.
1. I wrapped black cloth tape around the conical 'lock-nut'
2. I used a 'Chain-style ViseGrip' instead of a regular ViseGrip to distribute the force.
3. Apply slight clockwise motion using the ViseGrip to the silver conical 'lock-nut', while applying counterclockwise force to the wooden knob
4. Unscrew wooden knob
5. Remove ViseGrip and tape and unscrew conical 'lock-nut'
Old 04-08-2022, 09:54 PM
zray's Avatar
Received 1,662 Likes on 988 Posts
Mine unscrewed easily just using an adjustable spanner, ie crescent wrench on the flats of the nut.
No evidence of marring, etc.
Z
Old 04-09-2022, 08:55 AM
taylods's Avatar
Z
Yes. I think it's a 16mm wrench for yours. So many have had trouble with my type, which has no flats. Ours has the 3 indents on the locknut at 120 degree intervals.
The following 2 users liked this post by taylods:
JimmyL (01-27-2023), zray (01-27-2023)
Old 04-09-2022, 10:53 AM
STLTHMSTA's Avatar
I believe those indents might be for a small hook spanner type wrench. TM
Old 04-09-2022, 10:59 AM
Jon89's Avatar
Received 4,356 Likes on 2,849 Posts
^^ That is correct. Having that tool would make removing and installing the shift knob quick and easy. I do not have one....
Old 04-09-2022, 12:08 PM
zray's Avatar
Needing specialized tools to remove ordinary parts is unfortunate indeed.
Z
Old 01-27-2023, 03:15 AM
vmaxie's Avatar
Do U know what size spanner wrench is needed?
Old 01-28-2023, 04:06 AM
toaster's Avatar
Are you all joking? You can unscrew the knob by hand........................
Old 01-28-2023, 06:24 AM
Jon89's Avatar
^^ If that three-point collar is cranked up tightly to the base of the knob, you need some sort of tool to twist and release it. I replaced the knob with a custom one from British Autowood way back in October 2012 but I do not remember what tool I wound up using to do so. It may have been my smallest pair of needlenose pliers....
Old 01-29-2023, 11:24 AM
PKWise's Avatar
As explained. it is standard M8 thread and the knob unscrews anti-clockwise.
However, if you have the XKR (Leather Gear knob with metal Chrome inserts), then some people have found this very very tight indeed. Certainly beyond hand force to unscrew. The plastic core has a tendency to shrink and lock onto the thread. This happened to me and the gearknob was partially damaged during forced removal using a covered strap wrench.
Old 02-08-2024, 11:55 AM
tmattson57's Avatar
Does anyone know if a 2007 xkr shift knob will fit a 2001 xkr? Is an adapter required?
Stamford
08-24-2017 04:07 PM
dsd
07-29-2016 05:54 PM
rweber
05-20-2011 11:45 AM
jordannray
01-24-2011 10:09 AM
pezzonovante88
Interior
11-09-2010 08:45 PM
Quick Reply: Shift knob removal
