shifter switches
I was working on the wife's gear shift because it has been stiff to select gears. Lubed the inner works and it feels better. Noticed the two micro-switches on the right hand side and the rearmost one is missing the tiny metal finger that presses on the actuator button. What does this switch do and is this a major problem?
It has been a number of years since I last worked on the J-Gate. If I remember correctly the the rear micro-switch tells the transmission control module you are in manual mode and allows you to control shift.
To be sure put the J-Gate shifter in the #2 or #3 position and go for a spin. Does the trans shift normally up thru the gears? If so the switch is for manual control.
Unfortunately as far as I know the switch can't be purchased you have to buy the cam plate as an assembly.
Here is the recent thread on the topic that was mentioned above. It might give you some ideas:
https://www.jaguarforums.com/forum/x...switch-195836/
Oh my, it seems I forgot to update the results to my own thread. The microswitch tab dsnyder586 sent me fit like a glove and have worked like a charm. My problems were fixed.
teroks
10-02-2022 04:38 PM
super_jag
10-26-2014 10:33 AM
tony1963
07-28-2012 03:26 PM
MyfirstJag
09-07-2010 09:45 PM
