Shifter top bezel repair/replacement?
somebody else awhile back had the same type of cracks and broken plastic....what are the dropping on that thing to cause so much damage?!?
Anyway, that is part of the gear shift, the top piece with the P-D markings is not sold separate. Best bet is to find a salvage unit, sorry. Make sure the unit does not have any j-gate bulbs burned out...they're a bugger to replace.
If you've got the parts diagrams and microfiche-scans we have available on the FAQ, you can get your part numbers you're looking for...then start scouring the used parts scene. g'luck!
jagosaurus (03-26-2011)
neruda
10-18-2015 01:19 PM
