Shocks and struts XK8
Guest
Posts: n/a
I needed front shocks. After a pretty extensive search,I concludedthat Bilsteins were the best overall for a stock setup like mine. I have a '97 and Bilsteins were fitted from the factory.I paid approx $95 each from Turner Motorsports throught Shocks.com.
If you haveCAT suspension [auto adjustable shocks], then your options are limited to OEM; and the price you'll have to pay is a lot more than regular Bilsteins.
Ally Kat 97 (03-10-2013)
I am also looking at replacing the shock/struts on my 2000 XK8. The ride is terrible in the sense that it is very harsh. You feel every minor bump in the road and evern feel the different texture in the road surface. From every thing I have read so far is that Bilsteins are the best. I used those on the rear of my XJ6 and they were fine with no problems. Very interested in any comments regarding ride quality on these cars.
All you will have to do is unplug the control module in the boot. With it disconnected there will be no errors and none of the other system interacts with CATS.
n17gary (03-14-2013)
It is in the tire well, at the far rear against the bumper toward the right hand side (nearest the battery). When you lift up the tire cover you can see the top of the control box and the connector attaches to the bottom.
It's a small black box, maybe 4x6x1" that is held on by two 10mm nuts. The connector is long and narrow, with 35pins.
The first time you undo the connector it's easiest if you unbolt the module first so you can look at it. The connector hooks into one side and rotates down to latch. Hard to explain but it will make complete sense when you see it
n17gary (03-18-2013)
34by151
09-06-2015 05:14 PM
