Should I replace the head gaskets as well?
Pristine97XK8Convertible (05-23-2015)
My guess is you mean valve cover gaskets/ seals in which case the answer is good practice would say yes. You will also need a small amount of high temp RTV where the timing chain cover joint is. Most importantly do not over tighten, use a torque wrench and follow the tightening sequence. The covers are plastic and easily warped.
KarimPA
09-03-2015 07:32 PM
