Showing My Age
Showing My Age
Hi,
Unlike my car, im showing my Age it seams. Im trying to find specifications for torque settings on the sump and oil pick up for my XK8 1997. ive searched high and low, in the FAQ section and cant find it at all.
any advice appreciated on finding details such as this.
thanks
stephen
thanks
stephen
Sump
2000 Jaguar Xk8 Engine Problem Oil Pan Gaket Replacement Fastner Sequence...
Can't help with the oil pickup, sorry.
However, since you seem to be a 'ph' Stephen you can be admitted to the JF Inner Steve Sanctum.
Steves outnumber everyone else because (we believe) only Steves are really bright enough to own Jaguars.
Admission is, of course, expensive but I will have my dear Ugandan friend contact you shortly for your credit card details.
steveeasy (06-30-2012)
Hi,
thanks
stephen
thanks
stephen
Both are 11 - 13 Nm
With torque settings, the lower figure is for used bolts and the higher is for new bolts.
This is a useful resource for information:
JagRepair.com - Jaguar Repair Information Resource
and this is a link to a Jaguar Specification book containing all sorts of information such as torque settings etc.
http://www.jagrepair.com/images/Auto...sb_09_2003.pdf
Received 6,315 Likes
http://www.google.com/search?q=steve+urkel's+%22Stephan%22+character&hl= en&prmd=imvnso&tbm=isch&tbo=u&source=univ&sa=X&ei =-7bvT43FL6SU2QXszYSBAg&ved=0CFYQsAQ&biw=1680&bih=86 9
Hi,
well ive got the tool and id rather the oil pick up does not drop of or come loose in a few months time, so I thought it makes sense. Im no perfectionest in any way and am a dab hand at doing a cowboy job on other machinary, but given the work involved in rebuilding an engine id rather make sure things are done properly.
After all steves know Best (meant in the best possible Way)
Best Wishes
Stephen
Best Wishes
Stephen
I agree. On tractors a socket and bit of scaffold pipe but on these things Isaac Newton Rules.
Even doing up the spark plugs was hairy - that washer seemed to squash forever on the first one and I had a little mental video running of how long it would take to get a heliciol insert into my lovely aluminium head. Never felt the torque wrench break with so much relief !
ps whereabouts in Lincs?
But I came up with a solution, now I just need to send 'a Steve' a PM and receive a prompt and personal reply without publicly looking like an idiot.
And if the OP is lucky enough to have access to a 'Talk Wench', then he should be happy.
Jaguar Forums Editor
Jaguar Press release
09-19-2015 10:18 AM
09-17-2015 11:18 AM
