shuddering vibration at speed
My 97 XK8 coupe rides smoothly at low speed, about 50km or so. Once the speed picks up, there's a shuddering vibration that seems to come from the rear. Otherwise it tracks straight. It gets a little stronger as speed picks up, but doesn't increase in frequency. The car is new to me, so I don't know if it has been doing this for long.
It also has the dreaded abs fault, though I don't think it is related.
Any ideas?
Any ideas?
olphart (12-21-2021)
olphart,
Well obviously the vibration is coming from imbalance of a motive element within the rear drive train. Some causes can be internal and others external. It is easy to inspect the external first and tick them off a list: Ideally, jack the whole rear of the car up so that you can rotate the wheels individually and check carefully.
Tyres - debris / damage?
Wheels - Debris / damage / balancing weights missing?
Brake rotor disks - Warp / damage?
Drive half-Shafts - damage / Tangled foreign body?
Universal Joints - Wear / damage?
Prop shaft - damage / Tangled foreign body?
Prop shaft end Joints - damage / wear?
With the above causes eliminated, the rest of the potential causes are internal and more difficult to inspect.
Wheels Bearings- Wear / Dry?
Differential - damage / Wear?
Gearbox - damage / wear?
PhilTrenbath
07-03-2018 03:47 PM
