Side lights stay on
Side lights stay on
Jaguar XKR 2000 USA Canada spec, convertible
When the ignition is on, car running I can control my lighting. However with ignition off and key removed my side lights stay on.
I tried a second hand light stalk, no change.
Have slaved in SLCM, no change,
Slaved in another security module no change.
Removed all brown and black relays in turn, Lights stay on.
noticed when the slaved security module was slaved in, that if the casing touch the bodywork then the interior footwell lights and instrument lights came on.
recently upgraded my internal lights, instrument and centre consul lights to LED.
have a security module fault that wont clear, say no ignition state.
On ignition off and key remove instrument display shows green lights on indicator, the after about 15 seconds main beam and indicators flash but main beam and indicators not actually on, only indicated on the instrument display.
any ideas would be appreciated
Received 2,408 Likes
The SLCM only manages the reversing and fog lamps:- the body processor module is the real controller. It should be possible to extinguish any relay-controlled lamp by removal of the related relay.
Did you have any problem before replacing the bulbs, and did you disconnect the battery before removing the instrument cluster?
Separately, there is a TSB for the 2000MY cars (attached) which may or may not be related.
If the 2000 is the same as my 2001, OP really needs to see what is happening at the BPM side light input pin.
This looks to me like a ground issue. Like the module electronics have no good path to the ground post on the battery. I would start investigating all of that with a meter.
JimmyL (03-08-2023)
Side lights now turn off when ignition off
I disconnect my battery at night.
rowanremote
Audio/Visual Electronics
05-26-2007 11:05 AM
