Side Mirrors
Well i would say you are right in thinking it's corrosion on the switch as i had the same problem. If you lift out the rubber trim in the door panel, then with a pry tool inserted under the switch you can lever out the small piece of trim to expose the screw that retains the switch. the switch will lift out(it is tight so won't just jump out) unplug, and switch is out. The switch can be opened up and i found the contacts on the circuit board had corroded through so i replaced with a good second hand part. I hope this helps. All the best. Anthony.
Flash-1973 (08-28-2023)
Grant Francis
10-07-2012 09:47 AM
