Side mirrow problem
Side mirrow problem
My new to me 2005 convertible has non functioning side mirrows. With the original swich, both left and right mirrows will only move inwards, left one, or outwards, right one. I thought the problem might be the switch so I swapped out a known working switch from my old XK8 and there is no change. Any thoughts?
Received 2,434 Likes
Don B (12-18-2023)
So good to hear from you Mike. Now that you mention it, the memory seats do not work. Lights come on when you press the set button, but no movement when the # 1 or 2 are pressed. I must tell you, this car does look and run great. Just getting through a few cat problems
Received 13,511 Likes
It is worth gently working the mirror glass left and right to confirm that it isn't jammed and that the glass is properly snapped onto the motor mechanism. If you push gently at the right and left edges of the glass, you won't hurt anything, but when you press it in all the way to the left or right, you may hear a click if the glass had become unlatched from the tabs at the sides of the motor.
Cheers,
Don
Cheers,
Don
Cheers,
Don
Cheers,
Don
