Side turn signals (repeaters) in mirrors
I just bought a magazine all about the Xk8. I'm there I found an article about a man who did a major upgrade to his XKR. One of the upgrades he did was put the side turn signals into his mirrors, like on a modern car. I searched on the web and couldn't find anything. So my question is:
Anyone know where to buy these or if this is a custom job done specifically for him? Because I love the way these look and would love to purchase some.
how to replicate:
- mark horizontal line at your favoured location.
1/4 inch masking tape is ideal for a 1/4 inch slot
- remove mirror cover
- cut slot
- fill slot with diamond pattern plexiglass light panel material from home depot,
about $5 for a 3'x4' panel,
can be flush mount or rear mount depending on your patience
with flush, you will not need to paint,
with rear mount, touchup of the raw edge would be needed
- set in some led lights and wire as needed
- refit mirror cover
note:
avoid dremels and such since the heat melts the plastic and
leaves a very ragged edge
smooth side out with the plastic
plastic can be dyed for a smoke effect/yellow effect
the flush mount can be made by sandwiching a larger
piece of smoot plastic to the inside surface of the
outside piece
- cut slot
note:
outside piece
Wolfy
05-28-2024 08:06 AM
