slidelljag - top latch issue
Welcome to the forum slidelljag,
I've moved your question from the Jaguar Forums Advice / Help & Suggestion Centre section to the XK8/XKR section. This is the place to post tech questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your Jaguar. In return you'll get a proper welcome and some useful advice about posting to the forum.
slidelljag; If it is your mechanical latch mechanism "hanging up", possibly just a good spray with some lubricant will solve the problem.
If it is electrical, there are switches at the top of the windshield; top closed switch, top latch closed switch & top ready to latch switch. Possibly a switch is not working consistently or has a bad ground.
What colour is the fluid - the new stuff should be green. If not you need to change it and flush the hoses.
Make sure the level in the pump reservoir is good and the Tee handled petcock is turned firmly clockwise.
Can you be a bit more specific with the problem - latching, unlatching or what?
OK changed the fluid and top moves much better. The problem is putting the top up with the top latch not coming up to accept the top. It worksgreat putting down. However, the problem is intermittent. I'm going to WD40 thelatch and check ground on swithes. Can I bypass the swithes to verify if they work by looking at the latch movement?
slidelljag (04-01-2013)
99xk8guy
06-05-2023 06:28 AM
