Slip Joint TSB for Buzzing Sound?
We finally tracked the https://www.jaguarforums.com/forum/x...g-sound-60533/ from underneath the car to a worn slip joint in the drive train. There is quite a bit of play in the joint. My indy shop owner mentioned taking the slip joint apart and lubing it to see if that resolved the problem.
I have been told that is a correct procedure according to Jag, and I am wondering if there is a TSB or other document outlining the procedure for my indy shop to use?
Thanks!
Thanks!
aholbro1
08-05-2021 05:02 AM
Poet
10-06-2015 09:40 PM
JagBrian
09-21-2015 07:17 PM
Dickie_L_J_O
09-13-2015 07:44 AM
