SLM/LCM:- failing resistors
Received 2,380 Likes
Thought I'd collate what information I had about the occasional rear lamp failure messages that may be caused by faults in the above modules.
I've included both the integrated SLM and the system for the older cars with a separate 'Lamp Control Module'
These internal components usually overheat before failing which makes the values hard to determine, so I hope this may be of use if your module decides to hold a barbecue.
Mike
Mike
The following 8 users liked this post by michaelh:
bazjag (12-26-2016),
dibbit (12-27-2016),
Johnken (12-26-2016),
markaltobelli2002 (01-02-2017),
motorcarman (12-26-2016),
and 3 others liked this post.
Hi Mike
Resurrecting an old thread, as its driving me nuts getting 'Check Rear Lights'warning message on the dash - only when I turn the lights on though, never if not.
Changed all bulbs in each rear cluster (using same brand) and have used electrical cleaner on everything including the electrical feed to both clusters. So....
Came across this thread where you have mentioned checking the SLM. Please excuse my ignorance, but where can I find this circuit board you have shown in your photos?
Many thanks
Jules
Many thanks
Jules
Redeye (04-19-2020)
Thanks for that. I'll have look later.
Warning only comes on when i turn the lights on, not when driving without them on - including reversing. Fog lights can only be used with the lights on, so I already have the warning appear.
All bulbs are brand new and all related fuses are good.
slay100
08-26-2010 12:55 AM
