SLM not functioning
So I did the flip key conversion. When I remove my transponder from my key I wanted to be sure I had not damaged it so I took it and the key and tried to start the car. It would not start first time so I held transponder closer to tumbler and then it would start. I finished flip key conversion and now have problems. The top will not operate. When I push the top down switch, the rear windows drop, but the fronts do not move and there is no pump action.
Also I can operate windows but not top using key in door.
I tried a hard reset but still no response from top.
The remote still operates door lock and unlock, lights on and off and trunk.
Any ideas?
Any ideas?
Received 2,398 Likes
I answered two threads
https://www.jaguarforums.com/forum/x...-158329/page2/
https://www.jaguarforums.com/forum/x...l-down-158804/
the last is where I jumped a relay back there. I momentarily jumped both up and down to find out which was which
yes, I cleared them and they keep coming back. I tried using an intact original key and not my flip key and I still get these errors.
the most probable cause as listed in jag trouble shooting is low battery voltage. It says 12 v so i am charging it. If tomorrow I don't get around 13 volts on it, I will go to sears to have battery checked out.
I will get a new VM as the one I have is an old analog one.
How does one check the digital signals from the control modules to each other?
everything works except top
the SLCM gets signals from Body Processor Module, Instrument Pack, Diver Door Control Module and Pax Door Control Module.
the errors come from instrument pack 1041 and body processor 1135
I may be talking to dealer soon
