Slow moving rook
Slow moving rook
The roof will open and close only with some help from me, that is, I need to manually push it open or close. Also moves slowly when it starts opening and closing. Any suggestions on what is going on? P.s. I did get a new battery thinking that would solve the problem - not!
Definitely check the fluid and if low check the main rams leaking. While you are in there checking the fluid make sure the bypass valve is fully closed. The valve is a mall rod with a T-type handle on the pump. If it isn't full closed clockwise it will bypass pressure when the pump is operating.
slojotaa
F-Pace (X761) / C-X17
10-16-2016 12:50 PM
Jeff DeVere
10-13-2016 07:00 AM
MikeofBonsall
10-01-2016 06:15 PM
