Slow tire leak.... any ideas?
One of the front tires on my 2006 XK8 has a very slow leak. I loses about 8 pounds of pressure per week. My mechanic (a great mechanic!!) says there is not a hole in the tire. He said the chrome wheels on my car are prone to corrosion. He said he could seal it up. It still leaks.
They are are chrome 19" Atlas wheels.
If it is corrosion, is there anything I can do to truly fix it?
I am curious... do the schrader valves leak? Could that be the problem.
Thank you!!
Thank you!!
BlkCat (11-28-2021)
The bead may be leaking. They pull tire and scuff clean any corrosion. I have that issue but with no corrosion. Water/soap around bead and see if there are any bubbles formed. Sometimes a rubber mallet to the sidewall will help seat a bead. If its corrosion , pull tires scuff and he may ad da sealer of some sort.
The following 2 users liked this post by XxSlowpokexX:
BlkCat (11-28-2021),
Timeisrelative (11-28-2021)
I've had this a few cars in the past. As a matter of fact I think my daily driver is a little suspect. The thorough cleaning of the rim did the trick a couple times but the tire has to come of for that. It'll take investigation which seems like a lot of work but I had having a leaky tire to keep track of. It's worth the effort. Yes, a valve can be faulty. You can get replacement cores and try one. TM
Chrome-plated aluminum wheels can develop bead leaks due to corrosion. My original "revolver" wheels (1999 XK8) got bad that way. I had to have the wheels turned on a wheel lathe to remove all of the chrome plating from the bead surfaces. Then they sealed up just fine.
However, they were still pretty ugly with corrosion, and i have since replaced them with powder-coated wheels. I will never own chrome-plated aluminum wheels again.
Bob Frisby
Boise, Idaho
Bob Frisby
Boise, Idaho
One of my tyres deflates very slowly, I don't use the car very often at this time of year but it needs about 8lb every couple of months putting in, or pro rata, I took it to the tyre shop who put the wheel in a bath of water but nothing showed up, I guess the leak is too slow to detect but it is a nuisance.
