small console lamps XK-8 and others
Greetings, This is my first post so forgive me if it's clumsy or in the wrong place. While searching for the strange little lamps in the heater/air conditioner control module as well as the other controls in the center stack I came across some useful information. There are two sizes of bulbs in the units. The larger of the two (Jaguar JLM11965) is a JKL Components DNW1-DW10 14.0 volt Neo-Wedge lamp. They are available (with removable green boots) from All Electronics. Their catalog number is LP-70 and priced 5 for $1.00 or 100 for $15.00. The small Neo-Wedge bulb is also a JKL Components part number JNW1-JW10 and available online at JKL Components Corporation for $1.50/ea without color boot. I have discovered the color boots can be carefully removed and reused. Don't tug on them from the top they split in half. Work something very small around the boot base and then up into the boot. Once loose they easily remove. I hope this saves someone time and money. When I priced these bulbs from a Jag distributor they listed them at $15.00 each - OUCH. I welcome feedback to help me better participate in this forum. Regards, Ken
MFoncerrada8 (10-13-2013)
Welcome to the forum Ken,
They could be the same ones that eventually find their way into a Jaguar packet and end up on the dealer's shelf!
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
n2audio
17
10-09-2015 10:53 PM
