Small oil leak
Recently replaced the oil pan gasket. Which took care of the vast majority of my oil leak. Still have a very small leak that accumulates at the bottom of the torque converter housing. I can't really tell for sure but the leak maybe coming from the crankshaft position sensor. (I am not 100% sure that is the name of the sensor). It is also possible it is coming from somewhere else. This leak is so small it is something I can live with. How difficult to replace the CPS? Is it something I could screw up or is it as simple as taking it out and putting in a new one?
Thanks in advance.
Thanks in advance.
there is a small threaded plug on the rear of the block just above the main bearing seal. one can only get to it by removing the transmission.
well you could do some preventative maintenance and replace the transmission A-drum. then this plug can be checked and one might as well replace the rear main seal while things are apart. OR, if the loss of oil is not significant, just live with it.
chtp66
05-26-2014 06:45 AM
FullThrottle--->XJR6
08-18-2011 09:58 PM
