Small Things - Removing Dealer Decal
I'm sure most of you have already done this, but it's been something I've been planning for a bit, but don't usually think of until I wash the car. So last week, after I got the car washed and the weather was warm, I got out the hair dryer and removed the dealer decal.
A little heat and the decal came off easily. After that a little rubbing alcohol took off most of the adhesive and the little it left came off with a small amount of lacquer thinner.
Before:
![](http://www.imagechicken.com/uploads/1274216827098989100.jpg)
After:
Before:
After:
![](http://www.imagechicken.com/uploads/1274216970043031900.jpg)
To remove vinyl use a "Lil Chizler" plastic razor blade available at a sign shop or supply shop. Using alcohol won't hurt your finish and still remove the glue, just keep a rag on it soaked to loosen the adhesive, a heat gun will help soften up a seasoned piece of vinyl. lacquer thinner shouldn't hurt newer urethane paints but I would rather be safe and use alcohol.
No change in paint color underneath. The car is garaged, so I am sure that helped. The sticker was on roughly one year. It was one of those low priority things that was wayyyy overdue so I'm sure it would have been even easier had I done it immediately. When I test drove the car they hadn't plastered it yet, but when I made the deal and picked it up, it was stickered.
I agree with you Steve, I removed the door guards when I repainted it last year It really gives the car a cleaner look, even more exotic looking (My opinion) The heat gun works well, but be careful not to bend them to much or they will crack with fine lines like the bumpers when they are hit. They make plastic trim tools that will help work the pieces up without scratching the paint.
Doug
01 XKR Silverstone
Doug
01 XKR Silverstone
Holden
09-05-2015 03:29 AM
davidladewig
09-03-2015 06:32 PM
