So now what's wrong?
I have a 2004 XK8 with 68000 miles. Great car, but it has a few bugs. I was hoping someone out there might know the cause. Here is problem #1, my tank was empty, so I went to the gas station to fill up. As I was leaving, I noticed that the gas gauge still read empty and the warning light remained lit. I tried tapping on the lens, banging on the dash board, no luck. Problem #2, side marker lights and license plate lights out at the same time. I thought all exterior lights are on the same fuse. I replaced license plate bulbs and still no go. Any ideas???
Received 2,193 Likes
hradical (06-06-2012)
unfortunatly jaguar likes to sometimes take easy cheap jobs and make them expensive. the sender used to be mounted in the back of the tank and took 5 minutes to replace with 1/3 or less. Now theyre inside mounted to the pump outer housing, and you may want to consider installing a new pump while in there since its a PIA job to do once. Much less twice.
I don't know if Jaguar changed this on newer Coupes.
On my 2002 XKR it's top of the tank mounted. And I did just go through it twice in the past couple days, first to replace the pumps. Then again the next day to re-attach said sending unit, because I knocked it loose attaching one of the pumps.
This resulted in readings that were either completely full, or completely empty depending on how I drove the car.
The price on Rock auto is $639.79, so the dealer price isn't far off.
dmatthewman
09-30-2015 10:10 AM
