Solar Battery Charger
Winter is around the corner and I do not have a garage and wanted to keep my car batteries fully charged now that the cars are not used every day. After much searching I found this Solar Panel at Harbor Freight 1.5 Watt Solar Battery Charger The price was right and the specifications 1.5watts seemed just what I needed. This is how I installed it in my cars Solar Battery Charger
The following 2 users liked this post by Gus:
JimC64 (11-08-2011),
Just Another Guy (06-04-2021)
Received 2,190 Likes
Are solar battery chargers worth buying? and what about other side of the story? We don't always have sun shining sometimes there is off gridcloudy and rainy weather too, what will we do in this kind of weather ?
Ron: did you have to get a “controller” or something like it to keep the battery from overcharging? If so, have you got a brand suggestion? I’m looking to do the same for my ‘03 XJ VDP which isn’t driven as often as it should be. I don’t have a garage and am leery of running a power cord across the common sidewalk to a charger to guard against a liability issue.
Thanks in advance.
Eliot
Thanks in advance.
Eliot
Eliot, The power delivery is enough to keep the battery into shape. It is a trickle charger that doesn't need to be unplugged when you go for a drive. The amount of current is keeping the battery healty and the alarm is working. It automatically stops when the battery is full so overcharging is no issue. I got mine from Westfalia. https://www.westfalia.eu/nl/shops/au...ne-energie.htm
Jzar
09-27-2015 02:55 PM
