Some Of Climate Control Lights Illumination Are Dim But Still Lights Up Is It Fuse ?
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
Every now and then when driving at night some of the Climate Control light becomes dimmer than the other lights illuminating on the climate control. Is there a fuse out or something or bulb ? Or do you suspect the bulb ? All the other lights are lit well. My rear defroster & circulation buttons lights on the panel is dimmer than the rest of the lights.
As recall, there's an extraordinary number of bulbs in the AC control panel. Although they look much the same, some have coloured sleeves. If some of the buttons look dim, it's possible you've blown one or more bulbs. Unfortunately you're going to have to take the unit out to tell which type you need.
If I were you I would replace the bulbs also while I had it out, they do fail enough to warrant that.
They are special bulbs. They only place I could find them was a Jag dealership. There are two sizes. The two behind the temp display are bigger than the rest of the bulbs.
Here's a link to a video which shows how to replace the bulbs.
http://www.youtube.com/watch?v=qiOAPgT4lXc&hd=1
If you are definitely getting variable illumination on the AC rather than lack of illumination (which would be bulbs out), dimmer module may be the cause.
Just to clarify, I do not think the dimmer module is defective, I just think it has a design anomaly which causes current bursts that can take out old tired bulbs under certain conditions.
The toasting could be due to the wrong bulbs, or just due to running the bulbs at high brightness for many hours and a less than optimal choice of materials by Jaguar for the holders.
GGG (01-11-2012)
rsa760041
23
09-25-2015 01:33 PM
Jaguar Forums Editor
Jaguar Press release
09-05-2015 10:08 AM
09-04-2015 09:18 AM
