Is this the sound of failing tensioners?
It is hard to tell. I lived with similar noises for way too long all caused by a failing idler pulley.
Easy and free to check. Losen belt. Spin pulley by hand. It must be a smooth effortless turn. My bad pulley had a stepped or ratchet feel.
Hope it's something cheap and easy mate. John
Hello everyone.
I've been hearing some rattling from the front of the engine lately. My xkr was made on 01/2002 by the way. What are some of the symptoms that you face when the tensioners need replacing?
http://youtu.be/q5xq_U77s_w
1. OLD TENSIONERS - increasing levels of concern each time you drive the vehicle
2. OLD TENSIONERS - desperation and remorse when they suddenly fail and wreck the engine
OR
3. NEW TENSIONERS - a warm, happy feeling when you drive the vehicle
You really want to go direct from 1 to 3. Too many reports on the forum of members who didn't.
This rattle may be the pulley (and the only way to be sure is run with the belts removed) but that doesn't take away the risk from failing tensioners.
I also have a 01/2002 build date. You may want to verify that you have the upgraded silent (and stronger) timing primary chain and pulleys in addition to the tensioners.
Reference my experience from about 5 years ago.
https://www.jaguarforums.com/forum/x...nsioner-55895/
Received 2,380 Likes
If your build date is 01/2002 you're most likely in the clear, if it's the first registered date then less so.
The serpentine belt pulleys (there are two) can be surprisingly noisy. My idler was on its way out after 33K, but the age won't have helped.
Obviously don't run the motor for long without the belt as you lose the water pump, but it's a cheap & easy fix. Worth replacing the belt along with both idler & tensioner pulleys in one go. Dayco do an exact replacement for the pulleys for around $20.
TBH I'd still pull the RHS cam cover unless I was 110% certain.
Good luck,
Mike
Good luck,
Mike
Good luck,
Mike
Good luck,
Mike
