Sounds like a vacuum leak
I took the car out of hibernation today and noticed an odd sound when blipping the throttle from outside of the car, not noticeable inside.
No error codes showing, you can only hear it with a sharp/hard blip of the throttle, ie high vacuum entering the intake tube.
Any thoughts, sounds like its coming from around the throttle body. I think I will have to dig out my smoke machine.
I'll also get Kim to blip the throttle so I can get closer to try to find the source, a bit tricky from behind the door.
Received 2,434 Likes
I was curious as the TB on mine makes a gentle buzz that varies slightly when the throttle is pressed. I hadn't heard it until fairly recently and wondered if it was something new. I'm guessing that I was just being my usual less-than-observant self...
I've just tried the same manoeuvre as you with very similar results. Somewhat quieter - but I didn't have the air intake off, so yours is likely normal.
RaceDiagnostics (02-28-2019)
PeteK812
02-01-2018 10:27 AM
jagnation89
08-01-2015 02:18 PM
