Sourceing Replacement Key Fob
So, I just got any old XK8 fob off of ebay, cheaply, that had the correct fcc number (US frequency). I think I paid 10-$15 each. Then used this procedure, allegedly for your model too. This is three fobs and two cars.
https://www.autoreservejaguar.com/ne...xkr-1996-2006/
Worked swimmingly with the three fobs and two cars I already had, giving me six fobs and two cars.
As the instructions make clear. All fobs for a given car need to be programmed at the same time.
Johnken (11-06-2019)
You can search Ebay or Amazon for new key fobs. Search for LJA2610AA. I purchased one and it worked just fine, $47. If you need more than one, they also sell them in multiple packs. Check out current Ebay offer https://www.ebay.com/itm/352453160791
GordoCatCar (11-06-2019)
Originally Posted by darbysan;2 Search for LJA2610AA. I purchased one and it worked just fine, $47. If you need more than one, they also sell them in multiple packs. Check out current Ebay offer [url
https://www.ebay.com/itm/352453160791[/url]
I purchased a generic Ford Focus (2000-2012) key fob off Amazon. Two for $15 !!! This could be programmed to my 2005 as is or the internals swapped to an original growler fob. The FCC number was CWTWB1U322. This is different for different years. If the FCC numbers match it should be programable to your car. Remember all the fobs have to be programmed at the same time including the original one.
