spare key
Old 11-26-2014 | 05:09 PM
jjf's Avatar
jjf
Default spare key
I only got 1 key with my 98 XK8. About how much does it cost to get a spare key made? Are they available on the internet?
Old 11-26-2014 | 05:31 PM
Stan I's Avatar
You can get one made & programmed from any reputable auto locksmith for aound $50.00.
reb1999 (12-05-2014)
Old 11-26-2014 | 11:02 PM
scottatl's Avatar
really, r u sure?
Old 11-27-2014 | 11:47 AM
Stan I's Avatar
Originally Posted by scottatl
really, r u sure?
YEP! Done it twice here in Ottawa.......
Old 11-27-2014 | 02:19 PM
floridabrian's Avatar
Default Keys
I have a quote from the dealer $350 (cut and programmed).
I have a quote from SNG Barratt
$100 (blank)
Going to check out the lock smith next. Understand they can do a cloned key.
Brian
Old 12-03-2014 | 11:31 PM
convgto69's Avatar
I checked in the Metro New york area and was told only the dealer could do it. I have a 97 xk8. Anyone in my area have a suggestion. Quote was over $300 from dealer.
Old 12-04-2014 | 02:05 AM
XKRacer's Avatar
I have a mobile guy, charges me £40..... Any locksmith can cut a key which will gain you entry its having a key with a transponder fitted and coded that costs, only takes seconds to do but the gadget to do it is what puts the price up........
Old 12-04-2014 | 02:56 AM
skeena river rover's Avatar
Is there not a way to programme it in the car. I had a range rover with a blank key there was a trick to programme the blank key with the car it worked like a charm. Dealer was charging $350 for it. After the pan rover forum i found out there was a very simple way to get the key programmed with the car as long as you had 1 original key.
Old 12-04-2014 | 04:27 AM
JagV8's Avatar
No trick to do that.
Old 12-04-2014 | 12:28 PM
RDMinor's Avatar
I bought two (2) uncut new transponder equipped master keys on eBay for $20.41 w/shipping but have yet to get them cut. That I will do on an upcoming trip to Tampa. I programmed the keys, I hope successfully, using the British Diagnostics IDS-SDD-WDS software and cable (v130.)
Not every locksmith can cut these keys as it takes an entirely different cutting machine and I'm told they're very expensive and there aren't enough cars using them yet to justify the cost. I figure if I can get them cut for $50 each I'll have done O.K. as the Jag dealers in Florida are all quoting $100 to cut and another $100 to $150 to program.
Old 12-05-2014 | 10:52 PM
rweber's Avatar
I went through the same process. The best key shop in town said they didn't have the machine to cut the keys. Had to go to a Jag dealer for the key and programming. My dealer is a 400 mile round trip!
Old 12-08-2014 | 03:11 PM
gradchief's Avatar
Have the same problem XK-8 2004 one key and only one key fob.
Local lock smiths cant replace either, not sure where my closest Jag dealer is.
I am in lower alabama on the florida line. Any ideas?
Old 12-08-2014 | 07:21 PM
Marsden's Avatar
Depending on your exact location, it looks like Mobile would be your nearest dealership.
https://www.jlrforms.com/forms/locat...n=Search&name=
Jaguar of the Gulf Coast
1419 E I65 Service Rd South
Mobile, AL 36606-2743
Phone: (251) 478-2228
jaguargulfcoast.com
Old 12-09-2014 | 07:36 AM
RJ237's Avatar
I just saw your post today. When I took my 97 to the dealer the cost of a new key was $45. They told me the early US cars did not have a chip. You might want to double check on that. A locksmith can tell whether or not you have a chip.
convgto69 (12-09-2014)
Old 12-09-2014 | 11:50 PM
convgto69's Avatar
Thank you. I will check into that.
Old 12-12-2014 | 06:15 PM
5V1900's Avatar
Default spare keys
I never realized how lucky I was to receive THREE keys, plus a green Valet key, with my 1998 - especially since I am the fourth owner.
bdboyle
09-16-2019 06:58 PM
oldjaglover
09-29-2015 04:27 PM
yarpos
09-27-2015 07:14 PM
Jzar
09-27-2015 03:55 PM
FabCat
09-26-2015 01:16 PM
Quick Reply: spare key
