Spares for a road trip?
I'm planning to take the XKR on a road trip through France down to Andalusia and back next summer and am starting to put together a box of likely spare parts to carry just in case.
The tensioners were replaced 1000 miles ago and I replaced the supercharger oil 100 miles ago. I will get a (very) full service before I go but was wondering what spares folk would suggest I take.
In addition to all the usual bulbs and fuses I have a new TPS, brake pedal switch & wing mirror in the box already for starters
Steve
Steve
worrasf (11-28-2015)
Serpentine belt - pretty cheap and always worth having a spare in the boot (trunk). Have you got two keys ? Assuming 'Yes' - I would get a third key cut - just the blade bit so you can open the boot, and keep this in your pocket or wallet. Then, hide the spare key / remote fob in the boot before leaving (maybe in a padded envelope under the spare wheel). So ........... if you lose your keys a very long way from home, you can get into the boot with the 'mechanical' key to retrieve the spare 'proper' set. Sounds like 'overkill' but losing your keys in the middle of a holiday thousands of miles from home isn't a happy situation, and this way, the spare set will always be with the car, but not easily discovered, should there be a major problem.
Finally - granny sucking eggs time I suspect - check current French & Spanish motoring legislation before leaving. I think the French requirement for two 'breathalisers' is still on hold, but there's other stuff about high-vis tabards, fire extinguishers, first aid kits etc., which seem the change almost on a daily basis.
Plenty of time to get organised well in advance !!
Yes, got 3 keys (4 if you count the valet) - I "lost" my spare so had another cut then found the "lost" one so I never paid the extra to get the third programmed but will be fine for opening boot and doors.
Steve
All good stuff - also going to take a roll of silicone emergency hose repair tape as I can't possibly take replacement hoses.
My luck may not be as good as yours, but I bring enough fluids to get me home, a roll of tape, a tire pump, some liquid tire repair, like Slime, or fix a flat, a tire plug kit, and one of every type of bulb on the car, and fuses.......I also bring my cat, but you will need to find your own........be cool.....Mike
+1 for the a/c
WTB[Europe]: XKR Brembo brake kit
Jagman28
11-19-2015 08:55 AM
Nerius
11-18-2015 05:08 PM
FS[MidWest]: XKR X100 OEM Speakers - Full set
Majik Lasers
11-16-2015 03:51 PM
