Spark Plug help please
Received 2,646 Likes
Timeisrelative (04-20-2020)
The ignition system in my 2000 was made by NippoDenso so I assume they also the same for your car. If you go to the Denso website and plug in your car it will tell you the plugs that will work in your car. The difference in spark plugs is heat range and type. I assume the original plugs were Denso but most brands make plugs that meet OEM specs.
jagosaurus
03-27-2013 06:17 PM
