Spark plugs?
Fuel filter?
My check engine light came up, and because of everything that's been going on lately I haven't been able to check the codes.
Symptoms are the following: Cold starts and sometimes even warm starts result in a rough idle that lasts about a minute.
The car feels a little sluggish.
Sometimes, specially when I've been crusing on the highway and decide to step on the gas to pass someone, the engine missfires before launching the car into warp speed.
I'm thinking spark plugs. Is that detectable by code scanner?
Oh, and I've gotten restricted performance message once, or twice for about a few minutes.
I had that thing wrapped in black electric tape last year. It's possible some of it has come loose allowing the leak.
I think it is high time I bought a new one.
You have a high heat level in that area and the tape will fail to seal the pipe take it from one who knows. Replace the pipe or do what I did but keep in mind it will not last.
I hope this helps.
I hope this helps.
+1 on Gus's recommendation and understand you don't have the 300 - I replaced all my coils just to do so. You will usually only have 1 fail which is $38 on ebay. How are your classes going?
air intake on ebay for $71
New OES Genuine Air Intake Hose Jaguar XK8 2002 2001 2000 99 1999 | eBay
I did win silver in my varsity judo competition, which means I'll be earning more mulah starting in august.
I'm gonna keep searching for that hose, if I can't find it, I'm doing what gus did.
If you cannot get a replacement pipe which is obviously the best option, use self amalgamating tape and not electricians tape. If you are not familiar with self amalgamating it kind of bonds to its self and it all becomes one piece, it has to be stretched between 30 and 50% of its own length to work correctly, however like all kinds of tape in this category, it is not heat resistant.
You could also try this:
OR
http://www.repairproducts.co.uk/page...FbMftAodGG0ASQ
OR
http://www.repairproducts.co.uk/page41.htm
I looked on ebay U.K and could not find a pipe, there were a few in the U.S though.
Good luck with your exams, hope you do well. My son is coming home tomorrow for a few days, he is doing his masters in music tech and has been told the uni will sponsor him for his doctorate next year, so its worth doing the work. Good luck with both car and studies.
Cheers,
Arty.
Update:
I resealed the intake pipe, cleaned the MAF (which looked shiny new with no oil) and I reset the codes. That didn't solve my problems. Codes are back with the same behaviour.
I gave up on that for a while as I studied. Today however, I had some free time and decided to monkey around with the car and the forums. I started by researching what I thought was an unrelated issue: fuel smell in the car.
This had me check the EVAP system. Although I didn't perform the diagnostics test on the Canister purge valve, I did note that A it isn't clicking and B my fuel smell does not come from the front of the car, nor does it feel like it comes from the back or the trunk either. It smells to me like it comes from the A/C.
I kept searching the forums and toying with the Jag. I dismantled my boot and checked all hoses. Nothing there except that I found that the hose next to the small one that goes to the back of the tank was disconnected. My dad had taken the car in for servicing years ago because of the fuel smell. I reconnected the hose but noticed no improvements. I think it's sort of a escape hole to guide rainwater out of the car.
Finally, I found post 83 & 84 by knowledge on the thread titled "gas smell".
So, he got the same three codes as me as well as most of my symptoms. I googled a little bit and determined that the sputtering and misfires could be caused, among other things, by a malfunctioning fuel pump or a clogged fuel filter.
The price of the fuel filter for these cars, at $10 for the ACDelco seems like a steal. I reason, even if that's not it, I might as well change it because I'm pretty sure I've still got the 14 year old original.
Thoughts?
I started smelling fuel today. It seems to have arrived along with my P0171 and P0174 codes. are the two things related? I have a 2002 xkr. Im about to search for those codes and see what the possible fixes are. The fuel smell bothers me more than the check engine light so I figured Id tackle that first. Also, there is a line that runs just inside the passenger side rear wheel that looks as if if may have been damaged from a flat at one time. Does that go to the purge valve/or canister in the rear? Its a hard line.
yesterday I changed my fuel filter because I read that low fuel pressure could cause the two above mentioned codes along with the cannister that wont purge. I paid 10.99 for my filter. the fuel that came out was black and generally nasty and unacceptable. I bought the iridium plugs from the dealer but the check engine light went out right after I changed the filter while on my way to pick up the plugs. I didnt have any air intake leaks. Thanks to all the great people who provide input to this forum
Thoughts?
Yes. The fuel filter is located under the car. Lie down just slight before the left side rear wheel. Look around down there you'll see a small canister that is connected to a fuel line and is next to a small heat shield. That's your fuel filter.
In the tank you don't have a filter, but you do have the fuel pump.
Jon, I thought so as well.
So I was checking and have come to a small conundrum. Should I buy the purolator or the AcDelco? The AcDelco from what I've heard is identical to the OEM one. I can find it for $15 including shipping at rockauto or $25 at a local autoparts store. I can find the purolator for $12 at a local autoparts store. Not sure if it's worth my time to wait for the AcDelco to arrive in a few days or just buy the local purolator and have it changed asap.
I changed the fuel filter this morning. The old one was in fact the original. It even had OEM and Made in UK printed on it! The purolator I installed is nearly identical except for the colour. Speaking of the old filter, that old thing was as blocked as I was during the third physics test. No air could get through it when I blew on it. Also, some of the fuel coming out of it had a nasty black colour to it.
I'll be headed to the Shell gas station before taking my politics exam. I'll assess then if the situation has gotten any better.
Update: from my trip from the gas station, my butt dyno reports an improvement. The sputtering, stuttering, sluggishness and hesitance to accelerate due to fuel starvation seems eradicated. Although, the results are still inconclusive because I didn't get the chance to stretch its legs. I can at least say that from 0-30 she's responding much better. I also noticed that she's idling smoothly now.
A a side note, the CEL is still on, however, when I last had the codes read, I didn't turn it off. I guess I should either wait for this drive cycle to culminate or turn it off with an OBDII and see what happens.
