Special Tool Rear Bearings
99XK8, While rotating my tires I checked the top to bottom play on the rear bearings; I found movement. I also discovered I need to do a complete brake job front/rear and replace both the front strut mounts. I was researching parts when I was told I would need a special tool to replace the rear bearings. If this is true where can I order/acquire this tool?
Also, what the general opinion on replacing the rotors and pads front/rear with ceramic pads and slotted/drilled rotors vs. OEM?
philwarner
09-05-2015 10:05 AM
