Speedo Light Bulb Replacement
I've read how to remove the wood face and the cluster. One Tech said NOT to turn the cluster upside down, just unplug the two electrical connectors and slide the cluster out.
What will happen if the cluster is tipped forward 45 degrees so the face of the gauges are facing down? Will the needles fall off or what????
Thanks for the help
Mark
Thanks for the help
Mark
Received 2,193 Likes
Thats good doug, but tipping lets the dampning jelly ooze out of the gauges.....
NO SERIOUSLY THOUGH, IT CAN<<<CAN LEAD TO STUCK NEEDLE, NEVER SEEN IT HAPPEN AND IVE TIPPED A FEW BACK IN MY DAY...HAVE YOU TRIED SMACKING THE CRAP OUTTA THE TOP OF THE DASH??? THAT ALWAYS WORKS FOR ME(DID LAST NIGHT ON A CUSTOMER CAR TOO) THE BULBS TEND TO GET A LITTLE SURFACE CORROSION AND A GOOD SMACK MOST OF THE TIME MAKES ALL RIGHT AGAIN IN THE WORLD...WELL AT LEAST WITH THAT SPACE TIME CONTINUEUM THING
Thanks for the help
Mark
Thanks for the help
Mark
It will make every jag in the world simulatanously (spell?) stop running.
Tony K
03-26-2024 01:53 PM
