Springs
Stock height from center of wheel cap to bottom of wheel arch is 15.74.
If the top shock mount is bad, it will lower the measurement maybe 1/2" or so. Bad bottom shock bushing can account for another 1/4" - 1/2". When you start getting below 14.5", then your coils are getting suspect.
These are front coil comments. The rears are the same height when stock, but the parts mentioned play (somewhat) less of a role.
p.s. wheel size is not a factor since you are measuring from the center of the hub.
