Squeaking sound from behind center dashboard/panels: XK8 1998 US version
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
This started about a week ago and sounds like bits of plastic foam being rubbed together. I suspect it could be a tube or hose/pipe in there rubbing against some plastic part or other.
I removed the wooden panel in the middle then unscrewed the 3-instrument cluster (oil-pressure, clock, battery charge) and then the black plastic vent component.
That's as far as I've got so far and the "squeaking" noise is still there. So now I'm not sure how to get at other things in there because what I can see seems a bit difficult to remove.
My questions therefore:
- has anyone experienced this as well (I've seen similar cases in the forum but not really the same) - I don't think it has anything to do with noise caused by the vent inlets at the front of the windscreen because it's a squeaking noise and not a rattling.
- how can I get at the areas behind what I have removed already without having to take the whole facia etc apart (I'm very good at taking things apart but lousy at getting them together again)
Thanks very much for any help/ideas
Redan
Redan
Redan,
Oddly enough, I have just recently encountered the same problem. A squeak/chirping sound from the dash area. It’s NOT the defrost vent (another common problem for X100 owners). It happens only when the car is moving, but goes away when I depress the brake pedal, and returns when brakes are released. Is your situation similar?
I recall a mention of this in another thread from some time ago, but can’t find the info now. I did go out to the car and manually depress the brake pedal, and heard the offending squeak, just not as loud as when driving. I’ll make an attempt today to squirm under the dash to identify any loose bolts or obvious other causes for the squeak. Absent that, I’ll just liberally apply a spray lubricant to the area :-).
Perhaps someone who had a similar problem will respond...
Billieg (09-26-2019)
So, taking giandaniel’s advice, went out to the car to investigate squeak under dash, but checked the shock mounts first. Front left mount squeaking like mad. I assume that the braking pressure compresses the shock into the mount, and thus temporarily stops the squeak as I mentioned above.
This is why we check the forums! I’ll replace both front mounts...
Many thanks.
Many thanks.
I think I can actually help with this problem. A friend of mine had a squeak/rattle coming from the centre, or center if your american, of the dash. Drove him nuts trying to track it down. Even bought specialist listening device to try and track it down. He got there in the end. Something simple too.
Going to find if he actually posted the solution. BRB.![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I cannot find any reference to the noise on the forum. He told me about it when we met up. This is his profile on the other forum. https://www.jaguarforum.com/member.php?u=39588 Send him a pm/email and ask him. You can tell him FrankC pointed you in his direction. He knows a lot about these cars. Worth a try?
One Labor Day morning visit here made my life a whole lot better.
Thanks to you and the collective brain trust that reside here.
Again many thanks!
blindside (11-20-2020)
