Squeeling when cold
I agree. The belt tensioner may have lost its tension/spring that keeps the belt tight. If the pulley bearings are going bad, this is easily identified with a mechanic's stethoscope (fairly inexpensive in the auto parts store). You should hear a definite difference between the bad pulley and the others when listening with it. It will have a grinding/rumble sound.
JessN16
01-06-2017 11:03 AM
