srs airbag flash code 52 on 1999 xkr
I have been able to eradicate an airbag flashcode 12 on my 1999 xkr by replacing the ecu with a secondhand unit. However it now flashes code 52. The only code data I have relates to post 2003 cars and on that code 52 refers to passenger seat buckle. However that is not wired up on the older cars like mine. Can anyone advise what code 52 means on a 1999 car
chrismcc
chrismcc
I have the same problem after a battery completely discharged and tensioner replacement.
Do you know if the airbag mil switch off when the problem solved.
I have read that the problem can be a lower voltage of depoiement power. But where to control this voltage before the safing sensor ?
Is anyone can help me?
PS: excuse me for my bad english. I'm french.
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
We need details of your car to help you.
Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
dejaegher (05-17-2013)
Check the passenger seat buckle connector and make sure it is clean, this will involve removing the seat, an hours job. While you are under there, check the wiring loom for any possible short circuits or pinched wiring.
Also do a hard reset in case your battery charger has upset the electronics.
https://www.jaguarforums.com/forum/x...connect-74146/
34by151
09-06-2015 05:14 PM
