SRS electrical diagram wrong?
ok i am confused. Still trying to figure out the srs light. After running a scan of the srs sytem with the auto ingenuity system. i found that there is no comunication with the srs at all. i do have several SCP network errors but the SRS system is not on the SCP its on the ISO network. If i unplug the two front impact sensors i do get the 5 beep tones that its suppoed to give off. so i know it at least is working.
When looking at the diagram of the srs module pin layout and color. The diagram states that the harness connectors are supposed to be:
FC29 / 12-WAY / BLACK
FC30 / 12-WAY / GREY
When in fact on my car FC29 is grey and FC30 is black. Ok then it gets stranger.
The diagram states that the power for the module constant, and switched are supposed to be on FC30 pin#8 and pin#7 Which in fact they are wired to FC29 Pin#7 and Pin#8 Is the diagram wrong or am in need to a check up at the eye doctor? i have had two other people look at the harness with me and found that the connectors are switched vs the diagram.
connection, diagram, electric, electrical, exhaust, jaguar, module, power, schematics, scp, srs, system, wrong
