Stability Control Failure
Is your abs light on also? Here is some info from jagrepair.com to get you started:
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
There is a lot more available there. One thing to note: The resistance of the sensors is usually 1000- 1040 ohm. If the sensors and harnesses check out it is probably the solder connections to the abs pump. This is a diy, or you can send it to various repair services found on ebay.
Welcome to the forum. If you are having ABS problems please start a new thread instead of tacking on to one that is several years old, and include the year and model of your car.
If you haven't already done so, please visit the new member area and introduce yourself. Link:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Johnken (02-12-2020)
zdrapec
09-25-2015 05:49 AM
