"Stability System Fail"???
Several times on my trip I had that warning show up on my cluster. At first I thought it was related to downshifting while going through twisties or down steep grades. But when it happened 3 times without moving the shifter...and driving over "cattle guards" on the highway I think it is relates to the jostling of the suspension. Each time it would go back to normal after stopping for a break and restaring.
So....what would cause the monitor to set off just by going over some bumps?? Something loose in the sensor system?
Oh...I had a few other little glitches in the past few days of driving that I'm curious about. First, my door locks started repeating the open/close process several times, and fighting me when I use the key to open and roll the windows down. And, my mirror seems to have lost its compass. So, I have disconnected the battery for awhile and will do some 're-educating" they system. I hope it will help.
That's interesting as I am experiencing exactly the same two issues. I have had the warning a couple of times, usually after I have been driving for a while, but it disappears after I restart the car and the door locks have been doing the open shut cycle for a few days now. I had the door lock issue earlier last year, but it sorted itself out, until now, that is!
I suspect the warning is a dodgy sensor, or a connection, but time will tell if it gets worse and stays on for longer.
Greetings -
I was just doing a search on "stability control" and came upon this thread.
Four days ago I bought a 1997 XK8. This morning I also saw "Stability Control Fail" followed by "Traction Control Fail" on the dash. The car's driving and handling did not seem to be affected at all. I parked and turned off the car and let it sit for about 30 seconds. When I started it up again the warnings were gone.
I'm not sure what I should be concerned about. I do have worn tires and bad alignment, but I'm getting that resolved this evening. Everything else on the car seems to be fine (knock on wood).
Thanks all -
Thanks all -
I just repaired a 1999 XK that had the same problem, as well as the ABS light coming on from time to time. There was a broken wire on the passenger side ABS sensor. The wire was broken about 1 inch from where the wire plugs into the sensor. When you pulled on the wire the connection would be broken.
Oh, yes...the ABS light came on at the same time.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
