Staggered vs non staggered question
I have 19" staggered rims, 8" on front and 9" on rear. If I change to non staggered is there anything to consider other than all 4 rims being the same size?
Wil 9" rims work/fit OK on the front?
Will 8" rims look OK on the rear?
Any idea what the min/max offset is that can be used on both the rear and front?
For a brief period I had the 9" rears on the front of my car, and the 35mm offset is just about the max. The OEM 9" fronts are a 25mm offset.
The OEM 8" wheel was a little skinny for the back, IMO, although I suppose you could use a spacer on the rear to improve the look.
If you find a 9" with an offset between 25 and 35, it should be fine.
Jandreu (03-08-2015)
Mbourne
09-14-2015 09:21 PM
