Stainless Steel Brake Lines for non-Brembo Applications
I am considering replacing my spongy rubber brake lines with stainless [over teflon] steel flex lines. The Goodrich kit is the only shelf item I can source; however, it is for the Brembo calipers on the big brake Jags.
Most of the existing kits for other vehicles are sized in either AN (JIC) or UNF standards. Currently I am thinking about using a standard length AN line like Earl's Speed–Flex Line, and adapting the end fittings to our flared line ends and calipers through the use of AN to metric bulkhead fittings and/or banjo bolts. Earls and Aeroquip both have a good assortment of prefabricated swaged steel flex hose in various lengths.
There are a number of sources for brake line connectors and adaptors like Pegasus. Even Earls and Aeroquip carry a wide assortment.
http://www.pegasusautoracing.com/gro...=BRAKEADAPTMET
Before I dive into the project, I want to know if there is any obvious downside to this type of conversion using adapted parts.
Below are catalog pics from Earls:
Gordo
Gordo
Gordo
Gordo
Give these guys a call and see if they can help you with the SS flex lines:
FRSport.com
3940 W Segerstrom Ave
Santa Ana, CA 92704
toll free: 866-507-6853
phone: 714-515-4001
fax: 714-557-4223
Good luck
clubairth1
29
05-10-2024 12:57 PM
1964Daimler
09-09-2015 04:50 PM
philwarner
09-05-2015 10:05 AM
