Stainless Steel trim rings for Montreal 20" wheels...
Old 09-30-2012, 04:23 PM
Danster's Avatar
Originally Posted by xke1963
The BBS Detroit rims are basically one piece with a center section that bolts in place and holds the stainless trim ring in place. I replaced a couple of these trim rings on my own car and it really was not any trouble. The bolts are Titanium and torque to 11 lb/ft. The original trim rings are glued in place with silicone. Make sure all of the silicone is cleaned off and use antisieze on the bolts.
+1 not hard to do. Just go slow and use a torque wrench.
Old 09-30-2012, 06:45 PM
xke1963's Avatar
Originally Posted by Arland Green
So I would drive my car to you and you would do it on a day I had an appointment for- one wheel only, trim ring only is scratched? It is a 20" BBS wheel for the 2005 XKR - a nine spoke split rim design.
You can drive in or ship the wheel in with or without the tire mounted. Our current charge is $100 plus the cost of the trim ring. We also clean the wheel and offer spin balancing if requested (with tire mounted). Highly recommend you call ahead and have the trim ring held in your name.
n8ertot
10-11-2015 02:28 PM
Johnken
10-01-2015 05:07 PM
Glenn Barickman
10-01-2015 04:09 PM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
Quick Reply: Stainless Steel trim rings for Montreal 20" wheels...
