Stainless Steel trim rings for Montreal 20" wheels...
The BBS Detroit rims are basically one piece with a center section that bolts in place and holds the stainless trim ring in place. I replaced a couple of these trim rings on my own car and it really was not any trouble. The bolts are Titanium and torque to 11 lb/ft. The original trim rings are glued in place with silicone. Make sure all of the silicone is cleaned off and use antisieze on the bolts.
You can drive in or ship the wheel in with or without the tire mounted. Our current charge is $100 plus the cost of the trim ring. We also clean the wheel and offer spin balancing if requested (with tire mounted). Highly recommend you call ahead and have the trim ring held in your name.
