stalled
Hi Dodger,
Everything below is from my manual with respect to that code. May give you somewhere to start.
Hope it helps
Fuel filter/system restriction
Fuel system leak
Incorrect fuel pump output
IP sensor to ECM sensing
circuit; high resistance, open
circuit, short circuit to ground,
short circuit to high voltage
IP sensor to splice in sensor
supply circuit; high resistance,
open circuit
ground circuit; high
resistance, open circuit, short
circuit to ground, short circuit
to high voltage
IP sensor failure
Hope it helps
Fuel system leak
open circuit
to high voltage
IP sensor failure
dodgerjames (07-08-2013)
The MY 2002 XKs do NOT have a Fuel Pressure Sensor (a electrical device that connects to the ECM).
They do have a Mechanical Fuel Pressure Regulator.
There is no signal from this device that would set a trouble code.
If the car is a 4.2 Liter, then it would be a MY 2003 with a Electronic Sensor.
Are some 2003 Cars in the UK registered as 2002s?
Edit: Sorry, I just see that it's a 4.2 Liter. It must be (what we in the U.S.) call a 2003 MY. It would indeed have a Electrical Sensor.
dodgerjames (07-10-2013)
shootingbrake
09-23-2015 10:54 AM
