starting issues plz help
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
symptom: tuning over wont start
already check:
fuel pump
the spark plug (only one) it look like it may need to be change but its still had a strong spark
took the battery to (AZ) and they tested and its good
I drove it to work about a hour or 2 later went to leave started it up then it shut right off like it choke out or something.
Solution: took the car to the dealer and they replaced the fuel pump and fuel regulator.
already check:
fuel pump
Gus put together a non-start troubleshooting sequence. It's on his website:
JagRepair.com - Jaguar Repair Information Resource
Start with reading the codes. This should indicate what the 'something' was that caused it to shut down after starting.
