startup rattle
It could be a number of things so see if this is what you are hearing. You will find 2 video links for this problem.
From all I have read on the forums, the primaries are not likely to cause major engine damage. I'm sure you will continue to locate the source of the sound, and my next thought is to remove the fuel injection fuse, turn the engine over to build up oil pressure, the quickly replace the fuse and start. It may not be conclusive, but if there is no rattle it does make one suspicious that chain tensioners are involved.
magnum454 (09-04-2014)
Chuck Schexnayder
33
10-24-2015 10:20 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
