Steering problem
Steering problem
This has me stumped. I was having the classic XK8 intermittent ABS, Brake warning and loss of speedometer. Sent the ABS module in for rebuild but when reinstalled, nothing changed. Cleaned all plugs with contact cleaner also. Intermittent failure continued and then I noticed something strange. While steering in a curve, the steering wheel would have a slight jerk and then speedometer would fail immediately followed by ABS and brake warnings. If I turned the car off and restarted, the speedometer would work again and eventually the ABS and brake warnings would cancel. This has happened several times, each time following a slight steering jerk. Is there some kind of electrical steering assist that could be causing the problem?
pomosv
10-11-2021 02:12 PM
Aincite
09-18-2019 08:25 AM
